How do I know if I have an LSD 'box
Old 05-11-2009 | 10:22 PM
BenZS's Avatar
BenZS
Default How do I know if I have an LSD 'box
Hi
How can I check if my gearbox if defo and LSD box? I know you can tell by jacking up the car, but I cant remember what happens next! LOL Is it if both wheels off the ground and I turn one the other shouldnt turn?
Cheers,
Ben
Old 05-11-2009 | 10:33 PM
OldDan's Avatar
OldDan
If it's a VC LSD then jack up the car turn a wheel the other should turn in the opposite direction.
Old 05-11-2009 | 10:39 PM
TOMO's Avatar
TOMO
incorrect my chubby friend you turn a wheel and the opposite whell should turn in the same direction
Old 05-11-2009 | 10:43 PM
fiend's Avatar
fiend
Is the VC LSD from the Series 2 gearbox?
Old 05-11-2009 | 10:47 PM
BenZS's Avatar
BenZS
Yes i want to check if the box has a standard viscus LSD S2 RST box. So if i turn one wheel with the car jacked up the other should turn same direction? I knew it was something like that!
Cheers guys
Ben
Old 05-11-2009 | 11:08 PM
orionmojo's Avatar
orionmojo
yup, as above, alternatively, you could just put it in first, accelerate, let go of the steering wheel and if the car crabs to the kerb, its lsd
Old 06-11-2009 | 09:06 PM
christurbomad's Avatar
christurbomad
do a massive burnout!!!
Old 06-11-2009 | 09:08 PM
m4tt274's Avatar
m4tt274
knock it into a 'private' roundabout a bit brisc and se if one wheel spins up on exit.
Old 06-11-2009 | 09:19 PM
OldDan's Avatar
OldDan
I realised afterwards LOL
Old 06-11-2009 | 09:40 PM
Rich_bloor's Avatar
Rich_bloor
rich_bloor@hotmail.com
burnout and get m8's to take note if both or one wheel is spinning.
Old 06-11-2009 | 11:51 PM
Marsey_RS's Avatar
Marsey_RS
no if the wheel turns the opposite it is LSD not the same way had the same prob and i to thought it was the same way .... i had a xr3 box in my s1 turbo that went the same way put LSD in and drives like a turbo
Old 07-11-2009 | 12:11 AM
fiend's Avatar
fiend
Everyone is saying something different!
So should it turn the same way or opposite way?
Old 07-11-2009 | 05:51 AM
jonny s2's Avatar
jonny s2
opposite
Old 07-11-2009 | 09:11 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Just jack up any old car that defo dosnt have one, like a Fiesta, 106, Saxo, Mondeo, any Escort other than a RS, blah, blah, blah... See what that does and then your should do the opposite
Old 07-11-2009 | 10:17 AM
orionmojo's Avatar
orionmojo
Mine is LSD and both wheels turn the same way.
Old 07-11-2009 | 10:27 AM
ben_frst's Avatar
ben_frst
i vote do a burnout and look at the rubber left on the ground
Old 07-11-2009 | 10:34 AM
BenZS's Avatar
BenZS
I would do the burn out thing etc but the car dont run the box in question is in a XR2i running FRST set up the bloke i got it from didnt have a clue about anything and said he had a feeling the bloke he got it off said it had an ERST box in it with a slipper, i just got the car as a donor for my projet fez.When jcked up and turn a wheel the other one doesnt do anything , i have check this on my mk 5 Zetec S and the same happens! so no slipper in the 2i either!
I remember the burnouts i used to do my my ERST they were wicked both wheels lit right up!
Cheers guys,
Ben
Old 07-11-2009 | 10:44 AM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
take the shafts out and look thru the diff,
bar across = std
hole = lsd
Old 07-11-2009 | 01:08 PM
fiend's Avatar
fiend
I'm going to do this today, got an old XR2i in the garage so that won't have an LSD.
Old 07-11-2009 | 02:57 PM
Marsey_RS's Avatar
Marsey_RS
ok soz just been on the phone the wheels shoud spin the same way ..had this prob wiv mine i thought it was opposite way but it turns out it is the same way soz to the peeps that said this my mate has 2 s1 and thay and mine now spin the same way
dalmarshall
Ford Classics & Vintage
01-10-2015 06:46 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: How do I know if I have an LSD 'box
