View Full Version : Ford Escort RS Turbo
- Bore wash
- Escort rs turbo bumper moulding
- Erst clank
- which injectors after beiges on ofab
- can you still buy mef rear suspension?
- What gear oil to use?!
- Improve Front Brakes on Escort RS Turbo
- Whats the best ride height
- S2 Rs Turbo cowling
- Universal/aftermarket fuel senders
- C376 HRH
- Escort rs turbo problem child !
- Rear disc converted brake line set up?
- does anybody know my car e222krf
- injector upgrade need some info
- how difficult
- Rear lights (smoked)
- saying hello
- 25 mm lowering
- Nothing.
- Rear drums - series 1
- Hello and help please!
- MFI Vacuum/Boost hose setup
- uprated anti roll bar s1
- Escort rs turbo head gasket
- Anyone breaking a series 2 ??
- Focus RS MTX Gear Cables
- Uprated clutches and standard cover plates
- Steering column brace bar.
- Loom diferences, how to run standalone management
- What CVH oil pump...
- Did ford make rs turbo cabriolet ?
- mk3 escort steering rolling info
- Wanted Black series 2 rs turbo
- Thrust bearing help
- Is there any clean S1 about for sale ??
- Universal fuel senders
- B633 BYB, S1, info
- Finding a brake bar 'boot'
- New engine. 1.6 turbo or zetec N/A ? opinions
- Clutch issues
- Black rs turbo g659vtw
- Zetec turbo exhaust limitations ?
- Best head for power on a cvh
- Series 2 fuse box
- Gearbox Filler Plug Thread
- mk3 escort break upgrade help please
- Evolution chips and spec of your cars
- Zvh to zt swap
- Play in diff
- Heat protection for HT leads.
- Cosworth FWD engine in to a MK3
- Zetec bearing?
- Well...
- Custom Rs turbo inlet manifold
- Mk4 Rs turbo smoked rear lights
- Cosworth management price
- mondeo brake servo
- RS Turbo Self adhesive sound deadening
- Mfi to efi running issues
- What do people think of this sump?
- Low idle at stop??
- Zetec Turbo Boost pipes.
- 1600cvh best power
- Zetec head
- Zetec turbo gearbox
- Bumper captives
- finding new carpet
- Koni setting??
- Relay identification ???
- Rs turbo brake servo needed
- s1 interior trim
- Brake line advice
- fake s1
- Full braided lines from mastet cylinder to calipers.
- no heater no rad fan no indicators
- Engine rebuild
- Not Again! Oil Surge/leak issues on track. Suggestions?
- Plastic injector sleeves
- Rear Suspension Top Mounts : Choices and Experience
- Alternator issue
- Standard RST Injectors - Bosch Pt No.
- Brake bias issues
- Fuel pump help
- Hello! Question from Italy,please Help!
- Back bumper opinions
- E898UAX?? Does anybody on here know this car
- ERST,, Totally strip engine bay. Clean up. Replace engine. Rebuild old engine
- Rst hard to start when it's cold
- Oil in Turbo Hoses
- Pectel mapping
- Rs turbo vs vtec
- Brake servo/Master cylinder.
- Zetec black top or silver?
- 1.8 zetec oil pump
- Cooling Issues ; What do you reckon?
- radiator fans
- S2 1.8zvh engine help required
- Valve stem seals
- Group A coil or not
- rs turbo amal valve help
- Smokeeeee
- Zetec Turbo Oil cooler.
- ET20/25 wheel on esco mk4?
- Car won't turn off
- 2 part Speedo cable ???
- Few Pics
- What gearbox do I have?
- Opening rear quarters Mk3/4
- Zetec steel rods?
- Ford Escort mk4 floor mats, where from?
- Cancelling out Brakepad and dipstick light on auxiliary warning module Escort MK3
- Intercool fans - front or back?
- zetec/zvh sumps
- ZT inlet and cam cover.
- Worn camshaft
- B199 DGP
- Poor starting
- Original finish cvh rocker cover?
- Where to get set up... Based in South london
- Efi 1,4 cylinder head on rs turbo
- boost, actuator question.
- Cosworth management to omex
- What colour temp sender ?
- megasquirt maps feedback
- Xr3i efi (non-uk) -> Ofac/ofab wiring
- New square terminal battery
- Which LSD to go for?
- S2 Turbo H2 LGC
- Any s2 gods in Somerset?
- mondeo servo upgrade
- rs turbo
- Where to pick up Rpm pluse on EFI car
- Mk3 mfi to efi turbo
- rs rebuild nearly complete
- I'm new
- Brake proportioning valve not working due to handbrake issue?
- S2 suspension
- brake pipe / hose thread sizes
- ERST S2: Brake shoe fitting kit promblems
- Actuator problem
- Seized fuel sender
- Adjustable TCA's
- Injector for MF2 set up question.
- Ignition problem
- 15" TSW Venoms
- S2 rs turbo glass weight
- Ford orion rs turbo conversion
- Fiesta rs turbo fuel pump
- Single Samco hose
- Newman cam lifters clamp tool
- Doesn't stay on...
- S2 Skirt Rivets
- Who's running spacers, with stud & nuts
- So, whats the clutch options nowadays???
- Best place for forged pistons?
- Passenger door out of alignment
- Sump gasket
- Steering bushes
- Escort oil pressure
- Series 2 spec
- Help with loom connectors
- Crank journal sizes
- Help with k jetronic fuel distributor/or injectors
- strange noise coming from inside the car
- S1/rs1600i roll bar onto s2 rs turbo
- fuel pump part number
- Turbo removal
- strange afr on cruise
- full length IC fitted now cars running hotter much hotter
- Turbo repairs
- Engine build, standard head/cam or piper and ported
- Blue smoke issue
- Any decent car covers?
- Cambelt Change Issue ; running closer to the edge. Help?
- Removing original ford sound deadening
- Hi Spec braking issue.
- For anyone interested in actuator preload setting...
- Valve seals
- Modding mfi head for EFi inlet - am I doing this right?
- S2 master cylinder brake pipes
- Zetec turbo mtx75 mounts!?
- escort rs turbo boost pipe blanker
- RS turbo starting issue
- Mfi dodgy tps symptoms
- RS turbo fuel filter an hose fittings
- Escort rs turbo RHD to LHD conversion ?
- fuel pump question
- escort rs turbo with efi more power
- Insane fuel everywhere
- wheel spacer question on mk4 escort
- Turbo seals are gone! Upgrade opinions please stage 2 or 3??
- One of the many reasons I don't like using old Ford EFI....
- Colour Change?
- MK4 roof skin ???
- Higher pressure oil pump relief valve spring
- Going to Attempt MFI - EFI Conversion.. Just Painted My Inlet!
- T3 turbo ?
- ST170/Mondeo 300mm brake conversion guide
- Puma part for series 2?
- converting MFI inlet to fit EFI injectors
- Rs turbo gaskets
- fuel pump relay
- Rear bump stops...
- Rear drums help!
- S2 RS Turbo top boost hose
- Series 2 head dilemma
- Help!
- Efi turbo misfire issue
- Polybushes for S2 RST?
- Any other Escorts @ FORDFAIR?
- Gear box brackets??
- Rs turbo gearbox brackets
- Best Clutch for circa 220bhp
- rear tyres rubbing
- dip stick popping out
- What fuel pressure and Co on zvh turbo??
- Goodbye Karlos G... Hello Karl @ FPT!
- Bailey oil breather
- Ingnition ecu wires help
- Vin tag help!
- Rs turbo s2, spain.
- weird boost?
- Mk3 mondeo brakes what braided lines?
- anyone done ZVH on black top block ?
- Nearside bonnet Vent cover.
- Synchro to dogs?
- short shift?
- Zetec turbo c20xe pistons
- Strange clutch problem
- Another fuel tank help needed...
- What's needed for a nice 260bhp cvh
- escort rs loom fitment
- Ib5 gear sets and FD
- Water leak,cracked Head? Fixed. Now won't start! ignition issues!
- Sierra Cosworth Brake Conversion Connundrum - Help?
- Any way of telling what cvh gearbox i have is?
- Float type rods and pin
- Zetec Turbo Power
- Boot lid mk3 vs mk4
- Rear dumb brakes not locking with handbrake
- Electrical Problem RST s2
- Engine Mount Stupid Question
- MLR quickshift
- The felt/carpet/trim that is under the dash, over the pedals...
- Valuation for 90 spec S2
- Do I need new brake servo?
- Let me know what you think lads !
- Zetec turbo gearbox options - any help?
- Wiring in Boost Controller on OFAM
