PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. head bolts
  2. losing oil???
  3. what engine oil for s2?
  4. what boost can you run on 7:4.1 cr ?
  5. car was filmed today for itv
  6. Should i remove abs?
  7. 2wd cossie calipers
  8. need some pics
  9. rs turbo fuel tank
  10. probs with rst can any one help
  11. how to fit other ford wheels
  12. need help on my S1
  13. 5w/50 oil for a s2?
  14. got a clicking noise from cv joint
  15. oil leak on back of engine of turbo hose fitting
  16. s1 rad and cooler upgrade??
  17. scorpion exhaust
  18. S1 into S2
  19. uuuummmm strange one..help
  20. white smoke :S
  21. N/A CVH and RST CVH
  22. what are the differnces good & bad s1 vs s2
  23. intercooler jubilee clip size???????help
  24. Delocking my tailgate
  25. self adjusting clutch
  26. pr*ck
  27. Actuator?
  28. outer front window seals
  29. Cheers Radders :)
  30. Can an intercooler be too big
  31. Mongoose exhausts...
  32. boost settings
  33. early morning starting problems
  34. CVH head casting for big valves
  35. who has GRS radiator and intercooler
  36. Bottom End Wanted
  37. what is the yellow plug under the inlet on s2 rst
  38. wots it worth?
  39. whats the best suspension set up for a s2
  40. help with oil pressure
  41. Pistons........
  42. whats the best cam for my cvh turbo
  43. Transmitter in Efi. HELP
  44. Mfi injector upgrade?
  45. wheel nuts for diamond rs wheels
  46. Numbers on top of pistons??
  47. cheers jano
  48. AP Brakes
  49. turbo timer
  50. HELP ME PEOPLE---I REALLY DONT KNOW-SOLD
  51. anyone using st170 300mm brake disks and 2wd calipers??
  52. Help ASAP?
  53. Rs Turbo radiator in the boot mod
  54. S1 turbo question
  55. s1 panels
  56. Is my ECU chipped?
  57. FAO Dry Series 1!!
  58. Stack
  59. GRS or Radtec front mounted intercooler
  60. erst exhaust flange bracket
  61. headlights
  62. rear fog fuse??
  63. MFI to EFI
  64. insurance
  65. what have i done !!!!! 3rd to 2nd (update now with pics)
  66. brakes advice
  67. whining sound....opinions?
  68. NEW LOGO LAMPS.... GIVE US YOUR VIEWS
  69. Genuine s1 rs turbo front & rear repair panels on ebay!!
  70. radiators
  71. My new bottom end issues
  72. selling escorts?
  73. head
  74. shorten actuator rod
  75. Gearlinkage......
  76. Is this a con or not????
  77. Water pump......
  78. bleed valve
  79. thought clutch was slipping
  80. stalling
  81. Lowering springs
  82. RED S2 Escort RS Turbo spotted between Purleigh and A12 Chel
  83. how do you clock an RS turbo clock set?
  84. Boost Problem... HELP!
  85. Help please, non starting Series 1, its alive...very alive!
  86. Rear anti roll bar?
  87. black for red,red for black????
  88. S1 Red / Smoked rear lenses on eBay.
  89. my radiator problem
  90. 2wd cossy intercooler on s2 rst
  91. Zvh Water pump plate
  92. Help, Std clutch set up heigh
  93. cos management ??
  94. carpets for cars?
  95. tailgate
  96. dump valve
  97. White Smoke *UPDATE*
  98. radtec cooling gear????????????????
  99. turbo
  100. can you fit an xr3i/rs1600i inlet???
  101. Why do people think they have wrc blocks.............
  102. standard t3
  103. fao people with cossie brakes on their rs turbo
  104. low comp engine
  105. Bumper inserts
  106. ABS n HANDBRAKE LIGHTS
  107. CVH big end bearings
  108. tubular exhaust for rst
  109. can some one help me (s2 rear door cards)
  110. Cam Belt
  111. FAN BELT KEEPS SNAPPING
  112. Turbo rebuild kit of ebay question, have spare parts
  113. 56,000 mile S2 stood for 5yrs solid, never started..??
  114. oil filters
  115. zvh head gasket?
  116. Help Starting problems
  117. Brake pads
  118. Oil in the foot well
  119. rolling road results
  120. s2/xr3i fuel guage...
  121. s1 fan belt and track arm change needed
  122. Scrapyard tears
  123. Treat her mean and keep her Keen Works!!!!!
  124. zetec turbo whats else is involved??
  125. 2.1 zetec turbo pistons help
  126. accumulator?
  127. MK5 LOCK SET
  128. TOP SPEED?
  129. cvh low comp or zvh low comp?
  130. removing abs
  131. Efi TB's
  132. ABS light is permanently on
  133. grs
  134. Gearlinkage......
  135. door damage
  136. What is the best tyre size for 17'
  137. windscreen needed
  138. cutting out when below half tank
  139. new member
  140. fuel pump
  141. MFi Turbo Fuel Shut off?
  142. Some problems fitting my GRS radiator
  143. efi loom
  144. colour change
  145. new clutch slipping?
  146. Best BoV
  147. What Oil
  148. Do i need my amal valve
  149. need a web link
  150. abs
  151. rolling road
  152. new cam
  153. how far have you been ?
  154. could you guys help me with a couple of things
  155. gearbox problem, can't run in 1st and 2nd gear
  156. ht leads
  157. sunroof
  158. please help!
  159. ruff idle
  160. CAN ANY ONE HELP??
  161. black smoke
  162. fuel accumulator
  163. stering wheel
  164. Turbo
  165. Sticking wastegate
  166. Zvh Crank Sensor / Water pump
  167. 3 cylinders
  168. Thrust washer????
  169. Aroquip fuel & injector lines
  170. fuel tank issue
  171. new break discs what to buy
  172. on boost misfire
  173. quckie
  174. one for the datapost guru's
  175. S2 fuel consumption
  176. harsh throttle
  177. what fuel!?
  178. S2 owners
  179. rocker cover
  180. check out my S2 bits on fordsspares.com
  181. S2 Clutch??
  182. Pimp project
  183. binning the abs, does anyone supply the replacement pipes?!
  184. All ZVH owners....
  185. dumb question
  186. steeing wheel fitting help!
  187. central locking gone wrong
  188. rattle from top end
  189. amal valve
  190. Over spray on windows
  191. injectors
  192. spark plug gaps please help ASAP
  193. Knocking noise?
  194. s1 prob
  195. New Intercooler
  196. turbo
  197. 1800 cc?
  198. Running Problem
  199. fifth gear!
  200. s2 rs turbo wont idle
  201. whats the same?
  202. S1 will not go over 5000rpm.
  203. CO Potentiometer
  204. boostdrop after gearchange....??
  205. uprated breather
  206. MOT failures of not?
  207. HKS dump valve
  208. How do you adjust the mfi metering unit?
  209. Steering rack??
  210. rst colour.
  211. what would you say its worth then ...?
  212. custom clutch mechanism
  213. could someone also add this one sorry
  214. thats ma new engine in and running
  215. T3 Turbo
  216. gearbox
  217. What would you have a scooby or cossy
  218. what other turbos will fit my car
  219. Is my actuator goosed
  220. love it!!!
  221. where can i get 1 of these for a non abs?
  222. 7000 rpm?
  223. Steering column bushes
  224. suspension question
  225. BIKE CARBS
  226. EFI manifolds and possible theory for poor running?
  227. mfi bods help please....looks to be fuelling
  228. manifold to turbo
  229. Show us your series 2 rst on super t's
  230. rear disc conversion
  231. PISSED OFF!!!!!!!!!
  232. help!!wont start when warm
  233. s2 is dead!
  234. S2 central locking probs
  235. swirl pot in tank
  236. MS - 2 on rst
  237. suspension set up??
  238. series 2 lsd
  239. ECU question
  240. ECU question
  241. The 6631 mile Series 1 RS Turbo
  242. Mercury Grey Minter im still with you....
  243. Managment
  244. Escort rs turbo wheel offset
  245. Interesting boost question
  246. can the crank be ground???
  247. S1 and S2
  248. rs turbo fireing order
  249. MTX75 i my RST?
  250. uprated top engine mount??
