Thrust washer????
Old Oct 6, 2006 | 07:52 PM
rst steve's Avatar
rst steve
Default Thrust washer????
Just had my engine rebored and will be fitting new pistons, rings, big end bearings, oil pump, water pump all the usual stuff. My question is should i replace the thrust washers on the crank as well i thought they would have been in the big end bearing set that i bought but are not. I have measured them and they are in the tolerance specified in the manual just dont if i should get new or use the old ones?
Old Oct 6, 2006 | 08:13 PM
Rick's Avatar
Rick
no, reuse them.
Old Oct 8, 2006 | 07:24 AM
HORNETS7's Avatar
HORNETS7
reuse em , just to stop crank floating!
Old Oct 8, 2006 | 08:42 AM
rst steve's Avatar
rst steve
Thank you very much just put the bottom end back together with new shell bearings, pistons and rings just need to spend some more money now on an oil and water punp
155lee
Sep 6, 2016 11:10 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
155lee
Oct 24, 2015 11:11 AM
DavidK
Sep 27, 2015 02:55 PM
Kam B
Sep 24, 2015 10:40 AM
