who has GRS radiator and intercooler
happy with that
on there RS turbo,and do people rate them,thinking of having them on my s2 when i rebuild it!
thoughts please
thoughts please
happy with that
well worth getting then,does anyone use there other products like swirl pot and oil breather,as i dont understand what the do exactly!i know im think!!
#1 in Spelling Club
The white RST on the S2 Intercooler page of the GRS site is mine. The Intercooler fitted is the original GRS Cooler. As in, the first one ever made. It is far taller than the current models, which have evolved tremendously and are not as tall, therefore causing less issue's with bonnet clearance etc.
I now have the very latest GRS version fitted and it is great.
Hope this helps.
Hope this helps.
Formerly know as Puss
Originally Posted by Grahamxx
Originally Posted by puss
As far as i know its the same size im sure i will be corrected if im wrong
woohoo i got something right
ps as you can see Graham the rad is finally in But i think i lost the reciept and chance of a copy
Ask me a question!
Before Graham was making twin pass coolers he was making single pass item, from other coolers for us about 7 years ago (Saab900)
They were tried and tested on many peoples cars from our ends before the design was changed to twin pass & also the design changed again so we didnt need to cut away any slampanel etc..
Anyways, top quality coolers.
#1 in Spelling Club
Ask me a question!
Was not ment for you to take offence just explaining that there has been so much development in the GRS intercoolers.
Thanks to so many different people asking for changes, however small. Then for Graham to take that and make use of the info and make the coolers as good as they are now shows what sort of product you would expect.
HTH
Regards
Jano
HTH
Regards
Jano
can some one take some close ups of fitting the intercooler to the car, like how the metal brakets have been adjusted etc, i am finally gonna try and fit mine to my car when ive got my front crossmember welded in!
that pic is good ta, i think ive bent my straps the wrong way though cause i had the fan on the rad!
ive only got one fan does it make a difference?
the tabs on my one have been welded right on the front cause i have my fans on the cooler itself.
if you are sticking the fans on the rad then graham usually welds the tabs towards the middle of the cooler i think....
