right then, bought a chrome cambelt cover for my s2, I know its a rs turbo one as it has it engraved on it...
but it dont fit
everything lines up but the standard bolts are too short, the guy I bought it off on rsoc had it on an erst.
when you put it against the standard one they look identical, but the bolt is too short to catch the threaded holes on the block.
do I need diff bolts or am I just being a spastic?
i can get you some longer bolts if you want mate? some crome ones
could you get me some bolts to mate?,ive got the same problem,my bolts just catch the first thread and no more,usually works loose after a bit of hard revvin
no
so its a common prob then.. I cant even get the slightest lock on them
The bolt's from you standard belt cover won't be anygood them chrome/stainless steel one's come with longer bolt's with an alan key head when bought new.
