new clutch slipping?
Hi Huys I fitted a new clutch a few weeks ago, but I think its slipping in boost. Im only running 12psi so its obviously not too much power thats causing it. IS there any adjusting or something that I can do to help prevent this? Thanks in advance fro suggestions!
very much doubt yu can help this mate,, mines running at 12 psi and it slips like fooook on boost,, sounds like the car is wheel spinning,, i would advise u to go for a paddle clutch but you wont get a AP paddle for less than £250 dude...
im buying one next week
Don't mention ze Vor
It's torque that kills clutches. At 12psi, unless you have a good breathing 1.9 or 2l, you shouldn't be slipping a std clutch. A flywheels skim is a must.
slipping clutch
most likely rear cranckshaft oil seal, oil most likely contaminating the clutch hence the slipping. I always have my flywheel skimmed and have a new oil seal fitted when i do a clutch.
cheers guys. will invest in a new oil seal. Take it the gear box needs to come off for this? may aswell skim the flywheel aswell then
