brakes advice
brakes advice
wassup me bitches
I need some advice on how to improve the braking. I got front cossie setep and drums at the back I HATE DRUMS!!! Ive still got the ABS.
I was looking at things like braidied brake lines and was thinking of removing the ABS.
need some opinions....
You say you have cossie setup...so it should brake OK. Changing rear drums will give you nothing. I'd say remove ABS and put some DS2500 pats and good brake fluid... done
Bin the ABS leave the drums alone. They are quite up to the job at hand. Change hoses for braided and replace the fluid with new stuff and all should be good
The Enigma
12-09-2015 10:12 PM
