Should i remove abs?
Just wondering if its worth the hassel or not?why do people take it off?I am fitting saff cossie brakes soon if that makes a differance?
Ask me a question!
Yes - Remove.
Yes - The brakes will be better
ONLY if you do it right!!!
DO NOT CUT BELTS!
DO NOT USE THE SAME LINES
DO NOT USE THE SAME MASTER CYL
YOU NEED A NON ABS CAR AND REMOVE ALL THE LINE AND COMPENSATORS.
THEN YOU NEED TO CHANGE THE CYL RATING TO 23.
Any info you will need is here:-
http://oddkiddcreations.co.uk/forum
HTH
Regards
Jano
DO NOT CUT BELTS!
HTH
Regards
Jano
