FAN BELT KEEPS SNAPPING
HELLO PEOPLE IM ARFTER SOME ADVICE REGARDING MY FAN BELT ON MY S2. ITS GONE THROUGH 4 BELTS WITHIN A MONTH . IVE TRIED CHEEP ONES AND FORD OE ONES BUT NO DIFFRENCE. IVE CHANGED THE BOTTOM PULLEY IN CASE IT WAS SLIGHTY BENT BUT NO CHANGE ANY HELP WILL BE GREATFUL
CHEERS
CHEERS
Im not sure how your fan belt if fitted but assuming it is ajustable i would say it could be over tight or out of line i.e the two pullys are not parallel to each other. Worth a quick check
Originally Posted by TGTURBO
SAFE CHAV. YES MATE IT DOES SLIP AND SQUEAL
HOWEVER, i had the same problem on mine, which ended up being a result of a leaking the brake servo.
The servo was causing an air leak on the engine, and then when the alternator started to get loaded up with things like headlights, rad fan etc, the engine would struggle to idle because of the load the alternator presented and because of the air leak it would start hunting, which then led the alternator to slow, and when the engine was revved the alternator would try to stall because of the load and eventually the belt would slip once, and its a down ward spiral from there.
Each time the belt slips and squeals, it wears, becomes looser, etc etc.
Since fixing the running fault i have not changed it since. I went through 3 belts in 3.5k miles.
If you have cold idling problems and alike running problems it could be a similar thing.
check your pulleys for rough edges from stones being flicked up , i had the same problem with belts disintegrating. a metal file and some time under the car sorted it out
Adam Graham
06-09-2015 06:04 AM
