HKS dump valve
HKS dump valve
Ive found the t piece for the HKS dump valve. I was wondering if it can be done, as my baileys has a pipe at the top the dump valve and the HKS doesnt have any pipes that connect to it.
if you have to fit a dump valve then use a twin piston type! as this is the only one that the car will run properly with!!
most people will say "dont bother" and "your car will run roughly" with a dump valve!!
it will however run pefectly ok as long as you use a twin piston item! but unless your running very high boost you dont really need one unless you like the noise
Re: HKS dump valve
I c, cant i go for a twin piston baileys (the trumpet one)?
Im bored with my dump valve sound
Will sound different to the twin piston more of a 'wooosh' than a 'ptshhhh' lol
Originally Posted by Ad4m RST
Aren't the trupmet ones single piston blow off valves? can't fit that to a RST.
