MS - 2 on rst
MS - 2 on rst
Hi.
What di i need to set up ms on my rst?
that i have of parts is:
efi complett inlett manifoild with inj an all that
Megasquirt-2 V2 ECU
2.5 Bar Map sensor
12' MegaSquirt Wiring Harness (MS1 / MS2 Ready)
GM Closed Element CLT / IAT Sensor with Pigtail
GM Open Element IAT Sensor with Pigtail
Fuel Injector Pigtails - Bosch x 4
I am just planing to use it for the fuel for now!!
http://www.fastford.no/forum/index.p...=post&id=15990
http://www.fastford.no/forum/index.p...=post&id=15989
http://www.fastford.no/forum/index.p...=post&id=15988
http://www.fastford.no/forum/index.p...=post&id=15985
i have the efi inlet head to but i have not taken a pic of it
i also have the efi coil and "brain" (motorarft) but i dont need that when i just gone controll fuel?
so what more do i need??
wideband
MSStim21-K Stimulator
thanks
Megasquirt-2 V2 ECU
2.5 Bar Map sensor
wideband
thanks
There is no reason to change the temperature sensors for GM items. Also, why do you go fuel only? I would think the greatest benefit comes from the ignition.
07-10-2015 12:56 PM
