REMOVING RADIATOR???????
Hi peeps im about to fit my st3 t3 hybrid and im gona remove the radiator as it will make it easier to remove/refit the turbo but how is the radiator held in place???, ive removed the pipes but i can see clips n the slam panel how do i get the rad out?? cheers again
2 bolts 1 to the left bottom of rad and the other to right bottom of intercooler!
also u would undo the intercooler form the rad as well 2 bolts on top of rad/intercooler and 2 at bottom of rad / intercooler !
ive found removing the front bumper easier to remover rad/intercooler as well!
although if your just removing the turbo then u dont really have to remove the rad !
