Is it possible to remove the cooler of oil?
Old 15-02-2007, 08:57 PM
Impreza
Impreza's Avatar
Default Is it possible to remove the cooler of oil?
Very good, does it(he,she) know someone if there are problems in removing the refigerador of oil that has the RST?
I ask it because I rotate this one and the pressure does not take(catch) well the circuit of the oil and I will have to remove it during a season.
Thank you very much and I wait me entiendais because my English because it is a painful sorry
sorry for the failure of the title already arranges it
Old 15-02-2007, 09:23 PM
SafeChav
SafeChav's Avatar
ummmmmmmm
Anyone else understand that
Rick
Rick's Avatar
yes, you can remove it, but watch the oil temperature
Old 16-02-2007, 10:34 AM
rs shawn
S1 Database Editor
rs shawn's Avatar
Text translation makes it roughly about removing the oil cooler
Old 16-02-2007, 11:50 AM
Craigb
Craigb's Avatar
Impreza.
If you re-write it in spanish I will translate it.
Old 16-02-2007, 02:54 PM
Impreza
Impreza's Avatar
I sit(feel) it it was a failure my to put the title(degree) in Spanish.
Now I arrange it.
Then if I remove the cooler of the filter of the oil and put a radiator of oil,Can I to circulate the car without breaking the motor or the T3?ż
Old 16-02-2007, 04:26 PM
rs shawn
S1 Database Editor
rs shawn's Avatar
Impreza Todavía no seguro lo que usted significa. Escríbalo en espańol y yo lo traduciré a inglés para usted
Old 16-02-2007, 04:31 PM
Craigb
Craigb's Avatar
Ah,
He wants to remove the original oil cooler mounted before the oil filter and install and new oil cooler (assuming air cooled)
Old 16-02-2007, 04:35 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
The Modine unit is also responsible for the warming of the oil, aswell as the cooling of it.
It is possible to fit an additional Oil Cooler by fitting a sandwich plate between the factory Modine and the Oil Filter.
Old 16-02-2007, 07:50 PM
Rick
Rick's Avatar
Think this is a competition car so doesn't need the warming bit
Old 17-02-2007, 12:07 AM
Impreza
Impreza's Avatar
For rs shawn
(mi problema es que el enfriador de aceite de serie me da una presion de aceite muy baja en el circuito del aceite y queria saber si se podria circular sin el enfriador o es malo para el motor o si debo poner un radiador de aceite)
Old 17-02-2007, 12:02 PM
rs shawn
S1 Database Editor
rs shawn's Avatar
Impreza
Everyone's got is basically correct. He wants to know if he can remove the oil cooler as it gives him very low pressure in the oil circuit. Will it be ok to remove it totally and let the oil circulate on its own, will it be bad for the engine or must there be an oil rad?
Old 17-02-2007, 01:12 PM
Craigb
Craigb's Avatar
Im no RS tuning expert but how does he come to the conclusion of its causing low pressure. As far as I was aware it was just a heat exchange, The large (25mm ish) threaded pipe from the oil filter to the block is surrounded by the cooler which exhanges the heat throuch contact with the pipe?
Old 17-02-2007, 05:18 PM
PeterRST
Don't mention ze Vor
PeterRST's Avatar
I've once had the problem that the flap on the oil cooler was jammed. Swapped the whole cooler against the one from my donor car and pressure was fine.
Old 18-02-2007, 01:03 AM
Rick
Rick's Avatar
As peter says, if the cooler is dropping pressure, the flap is sticking. You can usually clean it and free it up.
Old 19-02-2007, 07:49 PM
Impreza
Impreza's Avatar
Does someone know if some person of here to position radiator of oil to his(her,your) escort?
You might say to me the one who is to see if it(he,she) has photos of his(her,your) car, thanks
And this for rs shawn, in order that he does not get angry jeje
alguien sabe si alguna persona de aqui a puesto radiador de aceite a su escort?ż
Podríais decirme quien es para ver si tiene fotos de su coche,gracias
Old 19-02-2007, 07:56 PM
rs shawn
S1 Database Editor
rs shawn's Avatar
You've just about got it on that one.
Anyone on here done it and can they post pics.
Old 19-02-2007, 08:17 PM
Impreza
Impreza's Avatar
Sorry Sorry
155lee
27-10-2015 04:55 AM
Fudgey
17-09-2015 01:06 PM
BRAM
08-09-2015 07:11 AM
hopper350
04-09-2015 12:53 AM
StephTell
02-09-2015 06:31 PM
Quick Reply: Is it possible to remove the cooler of oil?
