zetec turbo h/gasket?
A friend of mine is building his full zetec turbo engine and asked me what head gasket to use? I have done a few searches on here and found different answers to my question. People were saying use the standard zetec gasket, st170 head gasket and the RS Focus gasket (Which i thought was the same as a N/A zetec )
So what are you all using and FINIS numbers would be great.
it'll depend on what comp ratio he is after as all the above are different thicknesses so people use them to alter the ratio but all the above are safe to use on a turbo
focus rs is triple layer one i use that theres also a thicker gen ford one for focus rs for when the head has been skimmed! crazy_cage found it out! and is running it on his
Would you have a FINIS for that?
I'm currently using a five layer gasket made of two ST170 gaskets because I calculated my squish band too small by accident when speccing my custom pistons.
im not one for keeping info to myself like a lot of others on here.
its Ł66 quid the the others are only Ł33.
Just to confirm: I picked up the head gasket with that FINIS code and it is a 4-layer stainless gasket, quite similar to the ST170 gasket, only the spacing layer is thicker. I measured the thickness at 1.8mm too.
