going efi
going efi
ive decided to efi on my zvh as i seem to be having nothing but trouble with the mfi set up
few questions -
will my t3 bolt up to a efi head ?
can i still use my rocker cover , top boost pipe and charge carrier ?
and have i missed of anything important on my efi shopping list ? -
fuel pump
loom and sensors
cps
coil pack and leads
head
ecu
inlet and tb
injector rail
fuel filter
plugs and leads
few questions -
fuel pump
loom and sensors
cps
coil pack and leads
head
ecu
inlet and tb
injector rail
fuel filter
plugs and leads
Re: going efi
Originally Posted by Jano_OddKidd
Errrr yeah
How you gonna trigger it?
BUT!!!! if your block dont have a CPS hole in it then u will need to set a triggerwheel up or u will need to drill out the block for a cps hole like the FRST one or late 90 spec..
