Everyone with a 1.6 RST...
Mines got a piper 285T cam
A chipped ECU (no idea what it is)
Scorpion 4" Exhaust
-31 actuator
K & N air filter
And its running 14 psi
Ive no idea what power shes running anyone got a rough idea what power id expect with theses mods ??
Scorpion 4" Exhaust
-31 actuator
K & N air filter
1.6 FRST Block
Turbosystems Motorsport Ported and Flowed Head
Turbosystems Motorsport Cam
Matched inlet and exhaust manifold
Turbosystems Motorsport Chip
Turbotechnics Hybrid Turbo
K&N Cone Filter
Full Janspeed system
pushes over 200 bhp depending upon the dyno used
K&N Cone Filter
focus rs 1672
1.6cvh
lightened and balanced bottom end
wire rung block
low compression pistons
arp conrod bolts
helix clutch
mongoose exhaust
grs i/c
stg 3 big valve head
newman cam/solid lifters/double valve springs
piper vernier pulley
stg 3 t3 hybrid turbo
ava chip and modified fuel ecu
2 std fuel pumps
standard airbox
214@wheels 18psi
click for bigger pic
http://img.photobucket.com/albums/v4...hs/scanner.jpg
wire rung block
arp conrod bolts
helix clutch
mongoose exhaust
grs i/c
2 std fuel pumps
standard airbox
214@wheels 18psi
My old rattler was
1.6
grs front mount
stage 3 head
cossie 4x4 t3 hybrid turbo
low comp pistons
Vernier pully,Standard cam (whooo)
mongoose system
-31
superchip
std airbox with K&n filter
4 paddle clutch
stage 1 box Bernie jobby
225bhp and 218ibft
Tuned by the Jamers
1.6
grs front mount
stage 3 head
low comp pistons
mongoose system
-31
superchip
4 paddle clutch
225bhp and 218ibft
Tuned by the Jamers
before it come off the road...
standard bottom end and head with a piper cam
stage 2 turbo
chipped ecu
-31
scorpion system
drilled air box with k&n panel filter
cossie 2wd front intercooler
pace alloy rad
magnecore leads
and it made 196bhp @ 16psi
stage 2 turbo
chipped ecu
-31
scorpion system
pace alloy rad
magnecore leads
1.6cvh low comp.
t3 hybrid
stell rods
stage 3 head
t2 cam
5th injecter
pace chargecooler
pace intercooler
pace alloy raidiator
-34 act
hearts and diamonds chip
mongoose
etc
244bhp@18psi
t3 hybrid
stell rods
stage 3 head
t2 cam
5th injecter
pace chargecooler
pace intercooler
-34 act
mongoose
etc
244bhp@18psi
standard everything except:
PTS Tuning chip
-31 actuator
Drilled airbox with Jamex filter
Scorpion exhuast 2.5 inch bore
Kent cvh35 cam
Kent Vernier pulley
Stage 1 Hybrid Turbo
Silicone Leads
samco's e.t.c
I dont know any power figures yet as it hasn't been RR'd since it's rebuild with all the goodies mentioned above, will find out in the new year. Engine was running 140BHP with what I believe to be just the Zorst and drilled airbox before the rebuild!
PTS Tuning chip
-31 actuator
Kent cvh35 cam
Kent Vernier pulley
Silicone Leads
samco's e.t.c
Superchip
Uprated Actuator
Standard size turbo with 360 bearing
Magnex
Pipercross Panel Filter
Pace Intercooler (Soon to be a GRS)
CHD flowed head with standard size valves
Kent CVH35 cam & Vernier
Lightened and balanced bottom end with accralites.
197bhp at 15psi.
The last mod i did was the head and cam, which really wasnt worth the bother, and deffo wasnt worth the money...
Thinking of going back to standard cam
Uprated Actuator
Magnex
197bhp at 15psi.
1.6 rst,
std pistons, Arp rod bolts, non strench head bolts.
Ford rst H/G
Blow thro carb.
2" magnex xr2 exhaust.
Was,
T25, stg 3 head, kent 36 cam, 7.9:1 c/r
13.6@100mph, Avon 10-06 on 180bhp ish (on 16psi, but cam belt had jumped a tooth)
All recorded on a DD RR, in 28+ ambients, and 13 runs in 20mins
12psi- 179 Bhp/fly, 170 lbft/fly, 148 Bhp/wheel, 140 lbft/wheel
15psi- 186 Bhp/fly, 184 lbft/fly, 155 Bhp/wheel, 156 lbft/wheel
18psi- 191 Bhp/fly, 194 lbft/fly, 159 Bhp/wheel, 161 lbft/wheel
21psi- 198 Bhp/fly, 199 lbft/fly, 166 Bhp/wheel, 167 lbft/wheel
in next month or so,
T3, My own stg head, 8.2:1, newmans cam.
looking for 200@wheels bhp and lbft.
Ford rst H/G
Blow thro carb.
Was,
1 Post
1600 8 valve cvh lump with 139K on the clock
K&N 57i Induction Kit
Samco boost hoses
Chrome dump valve blanking plate
Mongoose 2.5 into 4" back box exhaust system
Power Engineering Chip (previously on E1.6 RST )
Pace Chargecooler (previously belonging to AndyRST)
AP Organic Clutch with Mk5 ratchet mod
CTS Stage 1 Gearbox
Made 203bhp and 213lbs ft tourque around the 100k mark @ 16psi
made 193 bhp and 196lbs ft tourque at Power Engineering Rolling Road day in February @ 18psi
Samco boost hoses
CTS Stage 1 Gearbox
K&N Panel Filter
Roose Sport boost, coolant & ancilary hoses
Mongoose 2.5 into 3" back box exhaust system
Unknown Chip
Pro Alloy Intercooler & Rad
Standard fucked clutch
Standard S1 Box
-31 Actuator
Other than that everything else is standard under the bonnet
181bhp @ 5066rpm & 206 LBS/FT peak torque @ 18 psi max boost
More in 2007 tho
K&N Panel Filter
Unknown Chip
Standard S1 Box
-31 Actuator
More in 2007 tho
Engine
Standard 1600 CVH
Kent CVH35 Cam
K&N Cone Filter
Magnex 2.5" Bore Exhaust
Samco & Roose Motorsport Silicone Hoses
GRS Evo 5 Intercooler
Unknown Make Of Oil Breather
2x10" Kenlowe Fans
Transmission
CTS Stage 1 Gearbox
AP Organic Clutch
B&M Quickshift
188BHP & 200lb/ft @ 18psi
a bit low on power for the boost but im putting it down to ambient temps of 40oC when on the rolling road (ACTs 50oC - usually 30oC on the road)
0-60 in 6.95 @ Trax 2006
Standard 1600 CVH
Kent CVH35 Cam
K&N Cone Filter
2x10" Kenlowe Fans
Transmission
CTS Stage 1 Gearbox
AP Organic Clutch
B&M Quickshift
grey's 2006 spec - approx 230bhp:
1.6 Power Engineering Blueprinted bottom end
Stage 3 big valve head (NMS rebuilt)
GRS Intercooler
Power Engineering SX428 cam
Turbo Technics stage 3 with -34
MF2 5th Injector
Power Engineering 2.5" exhaust system
this was the last time it was on the rollers for Cheshire RSOC RR day
ran it a week earlier at Nobles, as i thought the gearbox might die leaving a french toll booth en route to Le Mans
GRS Intercooler
MF2 5th Injector
1600 CVH
Lightened & balaned bottom end
Low comp pistons
Stage 2 head
Stage 2 hybrid T3 with .48 exhaust housing
Kent CVH 35 cam & vernier
ERL fifth injector
ERL water injection (not in use)
Pace full width intercooler
Scorpion exhaust
Chip
256bhp proven on a DynoDynamics rolling road (otherwise known as the "ego buster")
Low comp pistons
Stage 2 head
ERL fifth injector
Scorpion exhaust
Chip
#1 in Spelling Club
1600 CVH - 8-Valve
Low Comp - Forged Pistons
Steel H-Section Rods
Custom Big-Valve Head - Stainless Valves
GT30 Ball Bearing Turbo - 30psi
Omex 710 ECU
525cc Multi-nozzle Injectors
3" Exhaust (Turbo-back)
etc. etc.
350bhp - 310lb/ft
Lets see more power @ the wheels on a DD RR
but its running abit on the rich side on high boost, and lean on low boost.
Best to be seeing 0.80 thro out, (11.8:1 afr) but 0.85 is normally best for power (12.6:1 afr)
