Turbo Timer - any one fitted one
Fleet Manager
right have a prob aquired a 2nd hand turbo timer
its a B-11 starbo made by sanyo
need some wiring help if anyone can
its gout 4 wires
RED, GREEN, BLUE all thick and a thin BLACK
i sure all timers wires are the same red bein pistion 1 blue being 2 and green 3 black as the earth
but not sure whats what on my ingination switch
its on an F plate ERST
any one help???
its gout 4 wires
any one help???
Waste of time mate i wouldnt even bother especially if you have a category 1 alarm.
Can't tell you too much without knowing what wire is for what on the timer anyway, without it your guess is as good as mine!
S1 Database Editor
Here's the diagram for mine: could be the same..but better to get it checked by proper auto-electrician imo.
They'll also know which wire is which on the iginition.
Well iirc the thin black one is very long?? Well that is handbrake one. Then the red, green, blue as above in the diagram. Mine was cheap one from halfords, the auto timer works on the current from the ignition. Works pretty well. I will take picture of where wires go if it helps.
Fleet Manager
im fitting it as i have reomoved the water cooling from my turbo and i cant be trusted to let the car cool down
yer rs orion sound right to me mate nice one
Originally Posted by sykes
If you've got a cat 1 alrm make sure you wire before the alarm on the ignition, otherwise the alarm will only activate valet mode
S1 Database Editor
I don't think you need to evenif you could tbh..unless you rag your car all the way to your doorstep. Mine's a stand-alone unit and by the time I've parked, switched ignition off (so turbo timer kicks in), taken out stereo, got my mobile, bag and jacket and anything else I need, fitted disc-lock and then got out of the car and shut the doors it has normally counted down and killed the ignition. Then you simply press the key-fob yourself on the alarm to set it. Job done.
Fleet Manager
nah still wanna fit it,
what ya been before the ignition???? i have had the auto arm removed from my alarm as i locked my keys in more times than id like to say
not it only works when key fob is pressed
any one wired one on????
As far as turbo timers go if you wire one in, if you have a category 1 alarm you wont be able to fully arm your car until its turned off, hence why turbo timers are a waste of space (and yes i do have a turbo timer )
safe shave how do did u fit it then
They are very useless believe me.
Have your alarm set up to be a turbo timer, that way you won't have to wait and if you do it yourself it will also be free
Fleet Manager
it will be free as i have the timer sitting here infront of me, my alarm wont work that way i want to use mt timer just need some pic or someone to tell me what wire to conet what to and where to connect
S1 Database Editor
Get an auto-elect to do it. Mine csot me Ł20 to fit. Job done..and they do all the messing about removing the dials if nesccesary to fit the h/brake wire (to the red h/brake illumination wire before anyone asks ).
I just connected my handbrake one to the feed from the handbrake itself near the front right speaker. Theres enough wire there to do it and i didnt have to take any interior trim out. Yes i am bout to take pics now wen it stops raining.
marky_g what alarm have you got mate?
The ignition colours you want are:
Permenant 12v = Red
Auxiliary Wire = Yellow
Switched Ignition Feed = Black/Yellow
Starter Solenoid Wire = Black/Blue
Permenant 12v = Red
marky_g
15-08-2015 10:43 AM
