wastegate at stop but only running 6psi with -31 actuator
wastegate is at max after adjusting the acuator but im only getting 6psi on full boost, thats going up a hill in 4th, normally it runs around 5 1/2 psi
any ideas?
any ideas?
boost
i'm sure some one will correct me if i'm wrong but i would say your -31 accuator could have a weakened spring in it as ihave a erst that is pretty standard it still has standard accuator and it is running 9psi(not chiped either.)
no chip, no bleed valve, standerd engine not sure what is was running but it wasnt anywere near as qiuck as it is now, im guessing it was running about 1psi if that,
ive wound in the rod as far as it will go and im only getting 6psi
ive wound out the rod as far as it will go and im only getting 6psi
then take it to get set up with the extra boost youve added or it will end in tears
Originally Posted by NIMRODS_RST
surely your winding it the wrong way
first i thought it mite be on the limiter but it isnt, as i can bring it down to 5psi - 4psi etc, i just cant raise the boost over 6psi
i get a weird sound in high revs too, sounds like a heat shield is loose and rattling but it isnt
ive heard pinking before and this is different, i checked the emissions at work before christmas and the co content was about 1.3ppm which is slightly weak. i would go to a tuner but im sqint after buying a new gearbox (expensive lesson about powersliding)
im going to remove the turbo and investigate, is there anything i should look out for apart from the obvious
thanks guys for your help - much appreciated
I was have same problem. Boost wont go under 0.4 , but then I see that amal valve is wrong connected, and my boost gauge didnt work :-(
""""...co content was about 1.3ppm which is slightly weak.."
You mean that mixure is lean? I have about 1.30 %
did u unhok the eylet off the wastegate arm before u shortened the actuator rod?
if not the u will have torn the diaphram in the actuator hence no boost.
the rattling if its not pinking coule be the wastegate penny that isloose inside the turbo which will also cause the problem
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
