Ford Focus Mk2 rear brake light/sidelight problem
Old 11-07-2019, 03:08 PM
dylwms
dylwms's Avatar
Default Ford Focus Mk2 rear brake light/sidelight problem
Noticed today that one of my rear break lights was a little dim, upon further investigation I noticed that when I press the brake pedal with the sidelights on the sidelight on the same sude goes off. Anyone else had this problem?? Thanks
Old 11-07-2019, 03:58 PM
3i Jim
3i Jim's Avatar
Probably a bad earth. Check and clean the earth for the tail lights.
Old 11-07-2019, 04:33 PM
dylwms
dylwms's Avatar
Wouldn't know where to start ha ha
Old 11-07-2019, 05:42 PM
bigdel
bigdel's Avatar
The mk1 suffers a similar issue. Easily cured by replacing the brake light bulb holder. Only about Ł6 from Ford so a simple fix. Might be worth trying on a mk2 as the symptoms are indenticsl
Old 11-07-2019, 06:15 PM
dylwms
dylwms's Avatar
I'm going to do just that, will call in the local car breakers tomorrow see if I can get hold of one as the ones I've seen on ebay etc are 10-15 quid
Old 11-07-2019, 06:46 PM
RichieST
RichieST's Avatar
Either that or you have the wrong bulb in there, or its failed and its shorting across the 2 pins. I would change both the bulbs first and see if that cures it.
studabear (11-07-2019)
Old 11-07-2019, 08:24 PM
nick46
VR46 The G.O.A.T
nick46's Avatar
Yep defo change the bulbs first. I seem to remember I had a similar issue with my old Mk2 Focus, and it was because I'd put the wrong bulb in even though halfords sold it to me as being the correct one!
Old 11-07-2019, 08:42 PM
Moderator
STeve's Avatar
seen it many times with a naff bulb or rusted earth point on mk1& mk2
Old 12-07-2019, 08:13 AM
bigdel
bigdel's Avatar
EBay ones are over priced. Try Ford first, no point in replacing a potentially failed electrical component with another 2nd hand part that may have the same fault
Old 12-07-2019, 06:34 PM
I would defo start with checking the bulbs first.
Old 01-02-2022, 10:13 AM
piptime
piptime's Avatar
Default brkaelights
Yes, i have the same problem, brake light works when pressed, but put sidelights on, one side works but not the other of the brakelights
sbirch10
13-02-2014 12:30 PM
focii dan nick
04-02-2011 11:29 AM
26-04-2007 08:41 PM
vinnyd
Ford Focus RS
21-12-2006 11:39 AM
G1EN
Ford Escort RS Cosworth
29-06-2005 06:08 PM
Quick Reply: Ford Focus Mk2 rear brake light/sidelight problem
