Bonnet Lifters ?????????
Im looking in to having my work make some bonnet lifters up for me any body got any advice, size of blocks or tubing(seen these on ebay) please ? Do they help cooling alot lifting the bonnet up at the back ?
Any advice or info would be appreciated
Escort Rs Turbo
Ive herd they are one of the main causes of you're bonnet flying up if you dont adjust the catch properly . Plus imo they look pants and make it look as if you've had a front end shunt
i've got them on mine and they do help with cooling by relasing heat.
i was not a fan of them to begin with but they grew on me
the "oi your bonnets open!!" remarks just make me laugh
pain in the arse at the strip as you have the marshalls trying to close your bonnet!!!
works wonders - have you ever lifted your bonnet after a hard run and felt the heat the builds up inside?
also gets colder air to your filter which i have behind the headlight
i simply used three pieces of 20mm square tube , the whole bonnet is now lifted
mate
do not have pics on this pc , only at work i think
mail me at stevenb@denorco.com and ill see if i have any on my work pc , im back at work on Monday
i simply cut 2 pieces same length as the brackets and used
longer m6 bolts
the same for the catch , except you need to make another hole on the top of the 20mm square tube where the catch mounts to the bonnet , youll see what i mean when you take it off
hope this helps
longer m6 bolts
hope this helps
Also got them on mine and they most definately help with cooling. Also got twin fans sitting infront of the intercooler with the rad behind and temp guage never goes above halfway even sitting in traffic
They also look the nuts - just says power !!
Never had any bonnet problems - at the end of the day as long as your bonnet release is adjusted correctly you should have no problem.
The comments about my bonnet being open are hilarious.
But does get on your nerves a bit after a while but you learn to ignore it
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
07-10-2015 12:56 PM
Adam Graham
06-09-2015 06:04 AM
