T4 &cossie management
21-03-2008, 07:45 AM
would a low comp steel bottomend be ok with a t4+cossie management on it?whats the pro`s & con`s car will going to be main used on track
21-03-2008, 08:10 PM
cons......might be a tad laggy when tryin to get out the corners quickly!!!
Pro's.....will be bloody fast when it eventually comes on boost lol
21-03-2008, 08:19 PM
think you will be ok with it, as long as you can get used to the lag.
surely if you can judge the lag you can use the accelerator earlier to get the power delivery when you need it?
21-03-2008, 09:16 PM
as said above..
its just knowing your own car and getting ust to it...
21-03-2008, 09:21 PM
t4
Not a t4 but i had a t34 on my low comp 1600 and the lag was terrible, but when it boosted it went like fuck
21-03-2008, 10:33 PM
It Wasnt Me!
go 2.0 ZVH and it wont be so much of a problem?
22-03-2008, 06:43 AM
Quote:
Originally Posted by
vroooom ptssssh
only just finished build new engine mate it`s not even run in yet i thing if i told the missus i was putting an other new engine in it would be curtains lol
at least i can just say i`m buying a new turbo;-]
22-03-2008, 06:44 AM
Gregs
i`v have to slightly change the way i drive then mate;-]
22-03-2008, 06:59 AM
who built the engine? tell them what you wanna be adoing in the car and they should be able to spec you a turbo to suit
22-03-2008, 08:54 AM
me & my mate built the enging in his garage gus:-] were known has novice motorsport lol
22-03-2008, 08:58 AM
I would of thought the GT Turbo's would be better?
22-03-2008, 08:59 AM
then i would talk a turbo specialist and tell them your engine spec and what you want from the engine and they will spec it
no point putting mix match parts on, you will not get the best from them
22-03-2008, 09:23 AM
Spanner monkey
Personally, i'd go for a 4x4 ( 60 trim ) cossie turbo with a .63 housing!
22-03-2008, 05:15 PM
t4 1600 track car would be too laggy even when you learn how to drive it coming out of bends the revs woulkd be too low to spool the turbo up do as gus suggests get a turbo properly speced for the engine..
sean
22-03-2008, 05:49 PM
turboboss
sean
we will have to see about that sean
23-03-2008, 02:13 PM
Unknown.
Yours is slightly different Gus
You haven't just got a "T4 bolted to a steel CVH"
23-03-2008, 03:48 PM
if you dint drive like a fairy you wouldnt need a big turbo!!
mk3ste
17-10-2021 10:09 AM
gcfcos
59
06-10-2015 05:04 PM
griffo69
04-10-2015 11:58 AM
XR4
Ford XR Range
01-10-2015 12:46 PM
deathrider666
28-09-2015 06:12 PM
