Removing.....
Old Oct 28, 2004 | 07:11 PM
adamS2RST's Avatar
adamS2RST
Default Removing.....
S2 Fuel pump cradle.... Bolts that hold it to the body of the car are not a prob, although they are just turning, how can I get it off? Can't get the grips in where the wishbones are and it dont have a nut on the end so no spanner....wot do i do? ant the other one is in the boot aint it? Advice..... ?
Old Oct 28, 2004 | 08:35 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
coul ddrill em out n replace with new ones
Old Oct 28, 2004 | 09:07 PM
BODGE's Avatar
BODGE
the one in the boot will just keep turning m8 you will have to cut it off other side the nut to free it, the you need a new bit for the boot which has the thread on, i found i had to do the same with the other
mark
Old Oct 28, 2004 | 09:09 PM
BODGE's Avatar
BODGE
you can see the new part for the boot in the pic at the top in the bag, as you can see it needs painting
mark
Old Oct 28, 2004 | 09:33 PM
adamS2RST's Avatar
adamS2RST
Mark,
Was trying to think what that was from the pics....lol now I know. Yup, the boot one wont be suich a prob... I have been looking into the stainless steel jobbie AS do for about 50 sheets. It is a 3 peice jobby and it is a direct replacement I have been told, but I need to use my old flexi joints (rubber bits) I guess the ones on the pump itself, not the bit that fix's to the car ? Well I may well get that and see what I need, if not I suppose I can buy just the bit to bolt to the car as in ur pic mate
Thank's for your help guy's
Old Oct 29, 2004 | 12:17 PM
BODGE's Avatar
BODGE
the bit in the pic for the boot wont come with the stainless bits m8 im sure you get the two outer mounts, would love to see a pic of what it looks like?? if any good i may have to get one
mark
Old Oct 29, 2004 | 01:19 PM
T28 RST's Avatar
T28 RST
Ok then
mark
The bit in the pic isnt stainless, its just a metal washer on a bolt, i had to get this coz mine was rotten
Old Oct 29, 2004 | 01:27 PM
adamS2RST's Avatar
adamS2RST
Mark, Please see the below link for picture and details.... I was also told this from them:
Ref S2 petrol pump carrier our 3 piece carrier includes a 2 piece clamp which holds the pump then the outer section which bolts to the floor and holds the pump and its new stainless clamp without drilling new holes,all you need is to use your old flexi mounts ( 3 x small black rubber mounts) hope this helps.
The link to the full page is here:
https://secure.encryptedspace.com/au...t_detail&p=162
Old Oct 29, 2004 | 06:22 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
look ,,weld a large washer inside your boot over the hole left after cutting off the rusty item,(halfords sell em),,then get a nylock nut+bolt through onto the cage rubbers,,for the one on the wishbone side,,,you could try cutting it + drilling out the remaining to replace with a threaded sleeve,,(for a new bolt),or carefully drill a small hole through the bolt,,and slip in a retaining clip,or a split pin,remember to be carefull as its petrol petrol petrol!!
Old Nov 10, 2004 | 09:16 AM
adamS2RST's Avatar
adamS2RST
Still having fun with this, what you guys use to cut the bolt...can't get fook all on it?
Old Nov 14, 2004 | 04:05 PM
adamS2RST's Avatar
adamS2RST
got medievil on it's ass and went to work with the bolt croppers Let's just say the cradle looks like a mangled mess, but hey it is off, which is what i wanted Now gunna order the bling effort and get the other bits I need, sorted.
Old Nov 15, 2004 | 08:14 PM
akito-man's Avatar
akito-man
The DIVA
40
Sep 2, 2013 10:38 PM
