Clutch pedal
Well, Sometimes the pedal goes floppy, but when i tap the pedal gently it makes a click, then goes bak to normal possition & gets stiff like it should be, but giv it 10 mins & it starts to go floppy again, then click, etc..
Is my clutch cable nearly fecked or something more serious??
Can be tricky, but when u take the clip off the shaft, only slide the shaft enough so the clutch pedal comes up, don't wanna pull it all the way and have the the other pedals fall off and the little spacers.
focus rs 1672
unless you've got a head like a giraffe there tricky things to do
remember the order the washers come off they need to go back on in the same order
