cheapeast efi trigger wheel option
im almost finshed my efi conversion,swapping the head,inlet ect from the doner car(efi orion) tomorrow.
already fitted everything else
the last bit i need to sort is the cps
i dont fancy drilling the block,i have recently put a new alternator on and aint to keen shelling out for another to change the pulley over
is there a cheaper way.
dont mean to sound tight but am running out of spare cash for this conversion and would love to get it finished
cheers
cheers
Ive not tried it myself but apparently you can just change the pulley on your alternator.
So that with a trigger wheel set up would be easiest IMO
What are you doing with the block etc out of the orion aswell?
the block is just sitting not going to use it mate
so a sierra bottom pulley with the alternator pulley would be fine?
my uncle has 2 1800 sierras with the bottom pulley i need but he is a hoarder and wont scarp either car so i can get the pulley
Originally Posted by JesseT
Originally Posted by www.trigger-wheels.com
Some pulleys were fitted with 36-1 teeth from the factory
I've heard talk that this was a sierra bottom pulley, anyone shed any light on which car this came on?
That installation guide is useless, they show a trigger wheel on a pulley which already has a trigger wheel on it?! GOOD IDEA
bassy_g, you have PM
As far as which pulleys have teeth built into them goes it's all th CVH sierras.
The picture on the site IS NOT A STANDARD CVH pulley.......our cvh's have pressed steel pulleys, thats a cast item that already has a trigger wheel.......
I've not got one of the pressed steel CVH pulleys to hand, have you got any pictures?
BTW the web site has been updated albeit with more pictures of the "wrong" pulley style for you: http://www.trigger-wheels.com/fitting/fitting.php
Im still not sure you are grasping what i said. The pulley demonstrated there appears to be a CVH pulley that already has the 36-1 on it?!
Why fit another one?
The only page on the site that has engine specific instructions (I'm being careful to say engine rather than vehicle here) is the Rover V8 one: http://www.trigger-wheels.com/rv8/rv8fitting.php
Would it be better if the section that mentions the CVH pulley had all the references to what the pulley was removed?
jonfoc
16
11-09-2018 05:35 PM
Adam Graham
06-09-2015 06:04 AM
