can anyone help me source a prt?
I need the T piece that sits in the vacume hose to feed my ECU and my 5th injector.
can anyone point me in the right direction?
Many thanks
Pete
Many thanks
Pete
if your desperate, rob it off your washer jet water hose!
Lucid, any where that sells samco hose and alike sells them! Forge Motorsport are local to me, they charged me Ł1 each i thought that was expensive
If your really stuck for one im sure i can find you one and send it to ya
Actually im a pleb and found a cheap and ready supply just down the road at the local motor factors
my worry is that ill be using it for my fifth injector and i want something thats of reasonable diameter and not a skinny fooker like myself just so im not restricting pressure to the sensor.
many thanks guys if i have more props ill give you a shout
It Wasnt Me!
Whats up with that
Lucid, its only a sensor it doesn't need massive diameter piping, no real force needed to operate it
You never fail to amaze me
Whats up with that
Once again, amazed
Whats up with that
i just thought it would've restricted the amount of pressure on the sensor, good call safechav
James Porter
28-10-2015 12:17 PM
07-10-2015 12:56 PM
