mtx gearbox conversion
has anyone done this and got any feed back etc
where they had the drive shafts made and prices etc
i know one person who has done it but the welds on the driveshafts keep snapping so i dont really want to carry out the conversion if i have to keep welding up the drive shafts
Originally Posted by homer j
have a look at oddkiddcreations.co.uk. jano has done a few so it's worth having a word with him mate
i wouldnt go to jano after losing both my engines because he under fueled them. well pissed off about that. but i had an mtx 75 gear box in my 90's spec rs was really good. i have just broken my car for spears if you want all the bits to convert yours. got the drive shafts and my gear box also has full quilfe internal's
cozzy maddness if you can pm me a price for all the bits can you also do me an individual price for all the bits as well as i may not need them all
cheers ben
cheers ben
Can see where this is going
But tuning aside, i have heard Jano's MTX conversion kits are good, but from what i'm told its a bit pricey.
Just what ive heard on the grapevine though, so not set in stone
i know this isn't about fueling but i just wanted to say that i found out that my engines weren't underfueled because i was told today that thay both went due to being badly put together from the start.
so this had nothing to do with jano at all
really sorry if i have miss lead anyone
just been reading about this conversion on oddkid creations looks the business
heres a link if youre a member
http://oddkiddcreations.co.uk/forum/viewtopic.php?t=486
i have just completed mtx conversion into my s1,i run equal length driveshaft setup,i fabricated everything myself and made shafts,if you need any info,give me a pm and i will hopefully be able to help you.
i have also fitted t34 and full 3 inch zorst and jamsport 3 inch downpipe that bolts to 63 exhaust housing,so hopefully see some gains with these bits and bobs.thats why its goin ti take full day at ava to be remapped.
but even driving car at moment car feels much more stable,tighter and i would say better all round,no torque steer at all,is only 10 psi though,so wee have to wait and see.
will post few pics if anyone want to see.
http://i7.photobucket.com/albums/y267/wul/pics002-1.jpg
http://i7.photobucket.com/albums/y267/wul/mods055.jpg
http://i7.photobucket.com/albums/y267/wul/mtx19.jpg
http://i7.photobucket.com/albums/y267/wul/mods043.jpg
http://i7.photobucket.com/albums/y267/wul/mods014.jpg
http://i7.photobucket.com/albums/y267/wul/backofbox.jpg
http://i7.photobucket.com/albums/y267/wul/mods036.jpg
Originally Posted by Andy_R
Looking good Wullie top workmanship as ever .
Hopefully not long till you get it mapped and your flying again Look forward to hearing the results.
Give me a shout when your ready for mine
better waiting to see how mines does before jumpin into it m8,al be the guineapig,lol.
it it just a case of angle grinding a slice and tapping it all down or do you have to cut out a big chunk do you have any pics or the bits that have to be cut before and after and what where the drive shafts made from and where where they welded etc
Originally Posted by project rs
sorry to be so ignorant but why are thses boxes better. surely the box to have is the one from the st170 with the 6 speed
i made shafts myself ,apart from the intermedite fixed shaft,i had to make bracket to hold bearing to zetec block,as no off the shelf items fit,wasnt to hard though,both outer shafts are exactl same size,took lot time and machining,but they are 36mm thick and tig welded then balanced.
Not trying to hyjack the thread, but for peoples referance who want to fit the Getrag six speed from the ST170.
List of mods are:
Bolt in the whole gear lever assy including cables and cut a hole in the bulk head for cables - easy
Fabricate an inner wing gearbox mount - med
Fabricate a lower torque reaction mount in the middle of passenger footwell (approx) - harder
Shorten outer driveshafts and change hub spline for what hubs been run, sleave or get spec ones made - hard
Bellhousing bolts straight on if using the 2 piece Zetec sump - easy
Modify the flywheel to correct thickness as gearbox bellhousing and input shaft position was desinged for a thick double mass flywheel - med
Convert to hydraulic release bearing (no provision in bellhouse for mechanicl release bearing) - hard
Speedo drive - ?
Reverse lights - easy
Simon.
ps. looking forward to rolling road day in July.
List of mods are:
Speedo drive - ?
Simon.
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
