amal valve
03-06-2007, 03:06 PM
amal valve
is there any advantages when not running the amal valve?
if so how would i go about getting rid of it?!
cheers
03-06-2007, 04:56 PM
Don't mention ze Vor
Run it, if you have a proper working one.
With the amal valve, the ECU is able to control boost, e.g. lower it when detecting too high ACTs.
03-06-2007, 05:27 PM
If it works keep it.
On the same principal as "if it aint broke don't fix it"
03-06-2007, 09:00 PM
what are the signs of them goin knackerd?
03-06-2007, 09:22 PM
Being stuck in high or low boost.
For example if your car only boosts half as much as it should (about 3 - 4 PSI on std cars)
04-06-2007, 07:30 AM
as said before it allows the ecu to lower boost pressure if high ACTs are detected meaning less chance of melting something. if it's working correctly as advertised then you won't need a different setup so stick with it
04-06-2007, 03:23 PM
It Wasnt Me!
Mine broke, was hittin like 18psi if I floored it, so had to remove it
04-06-2007, 05:37 PM
steve.rst
15-03-2016 08:01 AM
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
rs_jim
19-09-2015 08:41 PM
