What Nuts to use................
Old 10-06-2007 | 10:38 AM
S2Dan's Avatar
S2Dan
Default What Nuts to use................
Need some advise if any one can offer it, trying to find the best nuts for my turbo in particular the ones which hold the 90deg down pipe to the exhaust housing.
For ages i have been constantly re-tightening the five bolts, it doesn’t matter how tight i do them up they will always come undone.
Now i am getting board, and need some nuts that are not gona come undone.
Someone suggested stainless steel lock nuts, but the only ones i could find were the nylock ones which not sure if they gona be any good with the temps from the turbo.
Any suggestions would be highly appreciated.
Cheers guy's
Old 10-06-2007 | 11:09 AM
SafeChav's Avatar
SafeChav
I always forget the proper term for them but you do need some lock nuts, but as you look at the nut the hole is slightly "squashed" so making it tight on the thread.
If you are just using normal nuts thats why they are working loose, because of the vibrations.
Old 10-06-2007 | 11:18 AM
Fiecos Dan's Avatar
Fiecos Dan
you can buy matal lock nuts, (not nylon) thats what i use, but will need to buy in a box of 50 or 100.
can even get St/St ones, but looking alot more.
or the other option is to use st/st ful nuts and st/st spring washers.
Old 10-06-2007 | 11:25 AM
Tombra's Avatar
Tombra
Old 10-06-2007 | 11:26 AM
SafeChav's Avatar
SafeChav
Thats the puppies
Old 10-06-2007 | 01:01 PM
S2Dan's Avatar
S2Dan
Thanks for the advise fella's
Those nuts in the pic, what are they called, and are these the ones you are on about SafeChav.
Old 11-06-2007 | 12:36 AM
SafeChav's Avatar
SafeChav
yea they are, look at them you can see the oval shape in the hole.
Dont know the proper name though
Old 11-06-2007 | 08:06 AM
Red16's Avatar
Red16
handy tip for you lads
if you need a lock nut but dont have any to hand...
with a hacksaw cut along the blue lines in the diagram until you break through in to the thread of the nut
then gently squash the nut a little bit in a vice in the direction of the red arrows
great way of making a locknut if you need one in a hurry
Old 11-06-2007 | 11:14 AM
SafeChav's Avatar
SafeChav
Red16 cheapskate
Old 14-06-2007 | 01:46 PM
JamboRS's Avatar
JamboRS
focus rs 1672
ive just had to take my turbo off and get 3 of the bolts took out my housing as they had snapped as the top 2 had worked themselves loose,its caused by not having a flexi in the exhaust and the constant on and off boost slackens them,get a flexi and your problem is solved i gaurantee it
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
cossie330
07-10-2015 08:22 PM
DavidK
27-09-2015 02:55 PM
Quick Reply: What Nuts to use................
