Sierra crank pulley on ERST
Skint Passionford User
I'm gonna be converting the cabby to weber sometime soon, I've got the 1800 cvh pully to go on with the 36-1 trigger ring on(that i'm having 31 teeth chopped off), but does it go straight on or do bits need machining off?
I've read somewhere that 4mm needs taking off it, but which side? Wanna try and keep the std alt. pulley and brackets if poss.
Ta
Ta
I tryed the whole sierra pulley thing.
Took it to a machinist and they got it down as much as they thought was safe, and when i tryed it on the car, it was missing the inner arch by about 3mm
Try and get a hole drilled in the block and use a cps on a fiesta rst flywheel.
Not worth the fucking about with the sierra shite
I'm gonna see if I can mount the trigger ring on the 1.6 pulley sonewhere and fab a bracket to hold the cps rather than pissing about with old sierra bits
The phase sensors in the dizzy on the cossie, so i'm looking at Jano Oddkidds phase disc set up that runs behind the cam pulley. I've no idea how its triggered though.
If I could find out what type of signal it is and how its triggered, I'd be able to fab something myself.
I'm supposed to be dong this on the cheap, but it's going tits up already
Davey.
OddKidd's setup works 100% on my engine and has never caused any problems. Every tuner i know who has looked at it has been well impressed and is used by many of them like.
Stu @ MSD
APT
Paul Hills
Ahmed
Grove
and OddKidd creations
The phase setup cost me under £100 and saved me so much hassle and time.
HTH
Stu @ MSD
APT
Paul Hills
Ahmed
Grove
HTH
i used sierra pulley when i did my conversion, also kept original alternater and just spaced the alternator pulley out further with a fatter belt from a local motor factors
jonfoc
16
11-09-2018 05:35 PM
