Do you know what pins to change...ive just bought a turbo cabbie with a fiesta rs engine and he has used the standard xr3i efi loom but changed a couple of plugs.....just want to check he done it right before i give it death...
if your going to use ofac management you dont have to change any pins at the ecu but if you use ofab management you have to change 2 pins,you also have to cut the wire at pin 2 on the edis module
