rs turbo chatter
#1 in Spelling Club
Originally Posted by chunt69
mfi can chatter but only at really high psi from wot i've heard
If an MFi car is heard to chatter, it will be slight and the best way is to run an induction kit, which will conversely be shit for performance. So, it's a case of what do you want? Chatter or Performance?
It Wasnt Me!
Mine did chatter the odd time, when I say chatter hardly more than a whoopoo lol but my turbo is pretty fucked...and need to be giving it tatties! as the turbo's got even more fucked It's not done it as much still holds boost tho 7psi
i just though it stood to reason it would get louder the more pressure the there was being used- my bad
#1 in Spelling Club
I can understand your theory, the logical approach, I think the higher the boost and RPM, the more 'shrill' the noise, the lower the boost and rpm, the deeper the noise.
Location: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
yeah mine shrills slightly,when its on da road! a slight sparrow warble tee-hee!stethescope needed tho!
i always thought mfis couldnt chatter as i was told a car chatters when the turbo spins backwards and as the mfi's have the non return flap underneath the air intake it stops boost for escaping back through the air filter therefor stops the turbo from being able to spin backwards and make the chattering noise.... cars that do generally chatter have an air filter straight on the turbo ie fiesta's and most rice motors
i second that said by Christian and Beccy
the loudest chatter actually happens at low boost.
but never heard mfi chatter myself
#1 in Spelling Club
The best there is,The best there was,the best there every will be. not the car that is
http://uk.youtube.com/watch?v=1-WOlB7FBCo
strange one as my turbo started to chatter when i had the boost raised! nothing like efi but it does it shutting off in every gear obviously when on boost!
My old s2 used to chatter really loud but that was running efi with the filter strait off the turbo ... It used to do a turbo in every month I hated it loved the sound tho !
Mine chatters stage 3 turbo technics turbo and a kn cone 16 psi boost
http://m.youtube.com/watch?v=hPGZZsbI8oU
And backwards into gravel for a swansong
Cheers PaulT
Cheers PaulT
oop's pmsl
what happend greasy track ?
JK12
33
26-04-2021 12:09 PM
