heat wrapped manifold ???
looked on ebay and seen the wrap,this any good ?
my car pritty standard with chip and fmic,
wil i benifit from wrappning my manifold ?
Originally Posted by chunt69
the manifold gets hot enough as it is, let it dissipate ffs it hardly effecting ur under bonnet temps in a turbo car imo
I had mine wrapped and it started melting the heat wrap. Manifold off and ceramically coated. Job done. Obviously there is a big difference inbetween a chip and frount mount cooler with some of the big power cars on here.
But then alot of heat can be achieved through the manifold if the timing has been retarded before peak boost is made.
Originally Posted by orion turbo
it would look better unwrapped on a tubular mani
but deffo got to wrap fords attempt at a manifold
I've heard differently from alot of people.
Wrapping the standard cast manifold is a bad move, holds too much heat.
Wrapping a tubular steel manifold is a good idea as they are usually used on higher performance cars which will produce more heat, so wrapping it will keep engine bays cooler, but can aid cracking
Pesonally i wouldn't wrap a standard manifold
#1 in Spelling Club
Mine is one of the only big powered CVH's that hasn't yet dropped an exhaust valve, god forbid. I'm sure that wrapping the manifold will raise the temperature in the engine and may make valve-dropping more likely?
In general, heat management is a good idea, but only once you are sure you're not creating a knock-on effect somewhere else.
well my converted 200sx manifold has been on the the car for over a year now driven really hard every time i go out in it and its never cracked or fell to bits yet and its heat wrapped
Exactly
07-10-2015 12:56 PM
caprixpack
25-09-2015 07:53 PM
