super chip on a erst zvh
right i have got a erst s2 2.0zvh and i want to know if ther is any way other than a super chip that i can turn my boost up past 10psi as im led to belive that the ecu cuts the boost off ther .
my car has not got the amal valve fitted and ther is no bleed valve too
and i thort it would boost into the high heavens
p.s i bought the car this way it is not something iv done to make the car super wicked cool man this worries me to be honest as im not wanting to blow my car up .
i want to run the car at around 12-14psi so im putting a bleed valve in between the turbo and the actuator so that ther is some restriction in boost but how do i get the ecu to let it boost past 10psi is a super chip the only way ?
G911 TTA
are u sure it isnt chipped already? put a bleed valve in between the actuator and turbo and play with it and see if it will boost to 14psi. if its not chipped it will boost cut.
only way to be able to hold a bar of boost is to have it chipped mate
i dont think it is chip'd as it will only boost to 10 psi at the min with no boost restrictions
Mc5506
05-10-2015 09:57 PM
