Engine keeps cutting out when cold
Old Dec 11, 2009 | 07:47 PM
NorwegianRST's Avatar
NorwegianRST
Default Engine keeps cutting out when cold
Hi i bought an xr3i with an 86 RST engine. Problem is that when the engine is cold i need to rev to about 2-3000rpm to keep te engine from cutting. When the engine is warm i kan keep it in idle without having to rev the engine. Anyone got any idea what might be acting up??
Old Dec 11, 2009 | 07:51 PM
liam-rst's Avatar
liam-rst
shit happens
sounds like idle control valve or cold start injector mate
Old Dec 11, 2009 | 08:14 PM
NorwegianRST
Are there any posibilities to test if the idle control valve is broken?? Thanks for the help turbocabessex
Old Dec 14, 2009 | 10:51 PM
liam-rst's Avatar
liam-rst
shit happens
yeah just unplug it while the engine is running an see if it runs better but to be honest i would be more inclined to think it was the 5th injector (cold start)
Old Dec 15, 2009 | 01:56 AM
conor.rst's Avatar
conor.rst
I had the same problem its the cold start if you ask me. i dont think that having to give it a little rev in the morning should effect the car in anyway so prob wouldnt get over worried about it.
Old Dec 15, 2009 | 12:41 PM
NorwegianRST
Yeah i'll give it a go. Its just an annoying thing, the main problem with the car is the wiring inside so. Cant find a wiring diagram anywhere for an xr3i
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
