Hearta and Diamonds ecu
ive not long got my erst, it already has a k&n induction kit, straight throo, s/s system, fancy leads and some silicon hoses, not sure off the bhp.
seen a hearts and diamonds ecu, the add says it can take 10 psi boost compared to the standard 8psi.
will i notice much difference from it?
is your s2 a early one or later one? if its a early one without a knock sensor then the hearts diamond hash ecu wont run the car properly as it will be looking for a signal from the knock sensor
here are the ecu types
blue white blue= s1 no knock sensor
blue white red=s2 no knock sensor 86-87 cars
blue red black=s2 knock sensor 88-89 cars
hearts diamonds hash=s2 knock sensor 90 spec cars
you can use the s1 blue red blue ecu on a s2 which has a blue red white ecu with no probs
aswell as u can use a s2 hearts diamond hash ecu on a s2 which has a blue red black ecu
but u cant use the first 2 ecus on a car fitted with the last 2 ecus and visa versa
DixieTheKid
14-09-2015 09:04 PM
