fuel pump?
it could be. but if its been sat for a while there might be shite in the tank blocking it thats causing the pump to work harder etc etc. 3 months shouldnt cause that much of a prob though. but its another thing to check.
how do you mean its getting harder to start?
if it helps, mine used to only buzz really loud wen i was running low on fuel and stopped sharply or turned harshly etc
but this was also closely followed by the engine cutting out, so that would be a fair old sign of noise due to low fuel lol
is it mounted in the standard fuel pump bracket? and is that mounted using the correct rubbers? iv been in a couple of RS's with homebrew fuel pump holders, and due to no rubbers to dampen the vibration, and bein mounted closer to the floor, the vibrations and noise r vastly increased
thanks lads i think it could be the low fuel issue but cant remember how much petrol is in the car as my gauge is fukd gonna half fill the tank and see what happens
how do you mean its getting harder to start?[/QUOTE]
when i go to start her she swings for about 30 r 40 seconds before she fires up she always used to start pretty much straight away but as it was parked for ages think i might change the plugs and leads and filters and see if this makes a difference
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
