Heater Matrix Removal?
How tricky are these to remove?mine has burst and im looking for some pointers on how to remove my old one.
Get the dash out as said and your left with this
whip all the pipe work off (i took pictures so i knew where every thing went) then theres two bolts on the underside of the bulk head take these off and it will drop down.
Almost forgot you need to take the hoses off in the engine bay and theres a little plate aswell that squashes abit of foam to make it water tight i dont know if you need to take this off or not but its only two screws so i did.
mark
mark
