top end rattle
![Thumbs up](https://passionford.com/forum/mages/icons/icon14.gif)
had a rattle on my top end of my s2 rst escort, so went out and changed the cam to a new kent cam cvh 34, with a new set of tappets, oil pressure reads 20psi on idle and over 40psi when revs are at 3000rpm, and there is still a similar tapping noise coming from the top, any ideas why?
G911 TTA
when i put new valve stems seals in my s2 it took few miles to quieten back down.
are the rockers definitely tite?
a top end rattle can also sound very similar to damaged shells in bottom end.my mate changed eveything in the head ,then found it was knackered shells
cam was run in properly 20mins at 2500rpm, is it a dodgy cam? the car was warmed up first before reading pressure gauge. 20psi at idle just over 40psi when revved at 3000rpm. the pressure never dropped. help me please!!!!!!!!!!!????????????????
always wondered what neighbours must think when you are running in a cam. RS Turbos are usually plenty loud enough at idle let alone at 2krpm for 20 mins lol
I have know a few people who have built N/A cvh`s and when running gave a top end rattle but only when it was slighlty warm to hot. After weeks of faffing about, it was discovered that the pistons being rough cast on the crown had a little more meat than normal. As the piston heated and expanded it was kissing the combustion chamber, this sounded identical to a noisey cam
Balls Deep!
![Content](https://passionford.com/forum/images/smilies/content.gif)
I have know a few people who have built N/A cvh`s and when running gave a top end rattle but only when it was slighlty warm to hot. After weeks of faffing about, it was discovered that the pistons being rough cast on the crown had a little more meat than normal. As the piston heated and expanded it was kissing the combustion chamber, this sounded identical to a noisey cam![Wall](https://passionford.com/forum/images/smilies/wall.gif)
![](https://passionford.com/forum/images/smilies/roi.gif)
Are you sure it wasnt that the head had been skimmed one too many times?
who squezzes there tappets before installing, f*ck i didnt could this be the prob if so what damage have i done, should i try squezzing them in with a vice .+++????????????
i think my heads going to pop soon mine and the bloody cars.
Oh no, you dont need to do this, a good soak overnight is all thats needed if fitting new jobbies.
JK12
33
26-04-2021 12:09 PM
