s1 and s2 dipsticks the same ?
got a s1 block in my s2, lost the dipstick, got a s2 dipstick from a mate, but it doesnt feel right
aye the sticks the same? and are the tubes the same lenght ?
cheers
cheers
Theres 2 dipsticks for the s2, a pre 90spec has a metal end and the 90spec one has a plastic end (just been readin a buyers guide for a s2).
dont know if this helps i just wanted to be a smart arse
the s1 dipstick tube is shorter than the s2 as i had to cut down a s2 tube as the s1 is no longer avaliable from ford.
The dipsticks are a different length, important that you have the right dipstick for the tube you have in your block
Has a large member
the s1 dipstick/tube are different in length to the s2 ones cant remember which but i wouldnt use your car until you got the right one as you wouldnt wanna over/under fill!
edit to say just saw gaz's post above. that'll be the right answer then lol
cars not getting used just now,, hasnt been for months
anyone no then if i change the s1 tube to a s2 tube then it will giive me the correct reading ??
I brought an S1 years ago, the guy fitted an S2 tube with an S1 stick and filled it to the max, oh boy, yes there was about 8 litres in the bastard, only realised when i booseted it and covered every square inch of the polish bay
Dr. Ickxs
15-09-2015 10:15 PM
