Fuel Pump wiring
Fuel Pump wiring
Im looking for the cable that controls the fuel pump relay in an rst s2 -87
ive been testing the cables on the fuel relay, the red and black wire got +12v brown one gor earthing, red/black goes to fuel pump i guess cause when i put in +12 the fuel pump runs, then there is the misterious cable in the middle its green and red, now whats this for, its nothing on it, and if i throw on +12 nothing happens and if i throw in earthing nothing happens.
what i know is that the relay is earth controlled right?
i ask cause im putting in a management that grounds the fuel pump output when it will go active, tried to study the wiring diagrams but dont find any clue =(
wire a new relay, that would be the simplest solution...have to do this when converting to Ford EFi cos its linked in with the injector relay, if theres no link with the injector loom, just use a Ford (yellow) relay, all my diagrams are on RSmania, you can find the diagram on Steve's RSbible site too tho
The relay is tachometric. It needs to see pulses from the negative side of the ignition coil. The green red is connected to the rev counter if I recall correctly. and then from there back to the ignition coil on a plain gren wire.
JK12
33
26-04-2021 12:09 PM
kosienutter
31
22-08-2015 09:55 AM
