What the biggest
Hey
Whats the biggest brake set up you can have behind standard 15'' wheels...
I need decent enough stoppers, when my zetec turbo is finished..
Not looking to spend £500-£600
looking for £250-£300 to spend.....
Ive heard that 2wd drive cossie disks and standard calipers are good? Any suggestions?
Cheers people
Cheers people
i fitted a set of 195 mm bremsport brakes that i got off of a fella on here!
they were about 600 quid and come with alloy bells!
look the tits and stop on a penny!
think it was NUTS RS that gave me the no!
2 w drive disc's plus brackets off Clint Gaskin (turbo sport £40) and keep your S2 calipers/ more power than 4X4 set up as the calipers sit right on the edge of the dics thereby more braking effort/use money saved to buy goodridges and (if you've got it) junk the whole 'abs' system.......then when you've got a bit more dough.
Brackets off Tony Pastie (zetec turbo £40) scorpio calipers and slider brackets off breaker (£25)(or new about £130) new discs Scorpio (£35 any motor factor) new pads (£25) M5 RS2000 handbrake cable (£30) break fluid
(£5/10) + one afternoon = car that stops just like a modern one!
Don't bother with Cos set up on the rear as you'll just keep swapping ends
as you hit anchors.
as you hit anchors.
Ben26
27-08-2015 08:56 PM
wimwerf
38
18-07-2004 06:02 PM
