Brake master cylinder and t-connection thread size
26-02-2006, 04:34 PM
What's the thread size of the outputs on the master cylinder and the inputs on the t-connection that sits on each side?
26-02-2006, 06:00 PM
Master cylinder
I wanted to know the same thing, does any1 know please?? sorry for replying to your post without an answer.
27-02-2006, 03:42 PM
Master cylinder for what?
27-02-2006, 04:18 PM
thread size
well i mean the connectors that connect the brake lines to the inner arch t-piece and to the master cylinder
27-02-2006, 04:25 PM
27-02-2006, 04:42 PM
thread size
dats correct, i was wondering what connectors i need because i junked the old ones and at my local parts store they got a few different ones.
28-02-2006, 08:45 AM
28-02-2006, 02:00 PM
Some of them are different but you will find the bulk of them are M10 x 1.0 Pitch yes
03-03-2006, 06:29 AM
I measured a non-abs master cylinder and the big one was M12x1.0 and the small one M10x1.0.
03-03-2006, 07:09 AM
I'm probably going to cut the old brake lines in two and reuse the connections on the new lines.
03-03-2006, 07:35 AM
brake lines
I got someone coming over to do my brake lines now, i have a diagram of the route that the non-abs lines take and the chap is going to do mine the same as that. Then he will block the two extra outlets that are no longer required. I will post up a reply and let you know how i get on and what connectors the chap uses.
[/img]
original
30-01-2022 08:20 PM
moesin2005
23-01-2022 06:28 PM
s1cab
26-07-2018 06:11 PM
Caddyshack
19-08-2015 07:29 PM
01 ,
05 ,
26401ae03a ,
accent ,
booster ,
brake ,
brmc63 ,
cylinder ,
fitting ,
gp ,
line ,
master ,
motorcraft ,
pontiac ,
rendezvous ,
size ,
thread
