Holding Back, Sounding like a Scooby & Backfire like ALS
10-12-2005, 06:00 PM
my s2 when i start it up for the 1st time of the day. my car is hard to start and runs lumpy when i rev her up as if she aint running on all cylinders. if i hold it at 3k it sorts it self out. i then drive it when i come on boost normally in 3rd gear it will hold back and sound like a scooby
sometimes it will backfire quit loud and pop and bang like ALS
. once its done that its fine for the rest of the day. but it does this everyday.
any ideas?
cheeRS
Rob
10-12-2005, 06:20 PM
10-12-2005, 06:50 PM
maybe its just cold
10-12-2005, 07:17 PM
mates did sumthing similer then changed to champoin plugs and never had the missfire problem again
just a thought
10-12-2005, 11:31 PM
distributor is quite a common fault its worth checking
11-12-2005, 05:07 PM
cheeRS everyone
11-12-2005, 06:34 PM
It Wasnt Me!
Mine does very simmilar, my plug leads are fooked so i thought it might be them as ive got brand new ngk plugs.
11-12-2005, 09:10 PM
if its not been run for a while then u should put new ford plugs, leads, rotor arm and dizzy cap on.
Timing also may be retarded.
11-12-2005, 09:33 PM
both ,my turbos do this for the first few minuets of running when there really cold.
11-12-2005, 10:11 PM
11-12-2005, 10:25 PM
11-12-2005, 11:33 PM
It Wasnt Me!
Yep ALS is Anti Lag System
12-12-2005, 12:51 AM
its runs everyday mate. i had it set up a few months ago and changed my plugs about 1 month ago. so its a bit wierd lol
12-12-2005, 11:05 AM
Ok, id defo check the dizzy cap though - any moisture in there is a no no. It actuallyu sounds like it's over fueling - have u got the cold start injector connected?
12-12-2005, 03:53 PM
i'll do that mate
yeh i have got it connected. worth taking off?
12-12-2005, 03:56 PM
Unknown.
yeh it is rob, if you dont know how, i'll pop round and do it
Its on the underside of the back of the inlet manifold
12-12-2005, 04:03 PM
mine does the same (startup misfire), just had new plugs, leads, cap, arm, setup @ Pramsport...
When i told jamie, he said it could be the injector seals...
worth a shot maybe? there were some on ebay a while back for cheap...
12-12-2005, 04:07 PM
12-12-2005, 04:08 PM
Unknown.
smiley
16-08-2015 06:36 PM
track.focus'd
12-08-2015 05:53 PM
Adam-M
22
10-08-2015 10:46 AM
blakey100
04-08-2015 08:17 PM
