S2 not running right
Picked my self a 90 spec s2 up at a bargain price lol in other words it going to cost me a shed load.
Its starts up and drives sort of it's got a miss fire though the rev range even on idle.
Done a compression test and there all between 120 and 115. But when I unplug the metering unit it seems to clear up the miss fire but won't stay running.
Is there anyway of trying to clean the metering unit or am I looking in the wrong place and it's something else.
Any help would be great
Cheers Andy
Cheers Andy
sounds like its runnng rich mate as said needs a set up mate don't mess with it yourself as i did as it ended in tears and a new bottom end but use a reputable tuner always hearing good things about jano i use jamsport because they are also good and are closer to brum than london there's norris motor sport in derby motorsport developments in blackpool you will be better off using a reputable rs tuner who will bring the best results out of your car
Eigdoog
13-09-2015 05:46 AM
