advice (picts inside) bottom end/head - also is the head ported?
Evening all,
So the lovely day which all RS owners come to finally arrived. The head cam off due to the cam and a tappet being munched as suspected.
The head was removed(been on car for 3years) and noticed the pistons looking rather caked! along with the top end, is this from running rich?
Also I noticed the head had been welded as seen here:
So should I ditched the head, is this bodged? Also what are the standard inlet/exhaust port sizes?
Many thanks
Dave
Many thanks
Dave
I'm no expert but I'm sure I've read somewhere that when the heads been welded its to allow use of a differant headgasket, focus rs springs to mind
cheers mate
pinched this from the site
"The oil feed to the Zetec head goes closer to the edge of head than on the CVH and if you put a Zetec head gasket on a CVH head the oil just leaks out the gap. You can get the side of the CVH head built up with weld and then the head skimmed to enable you to use Zetec head gaskets."
Wye Valley Hardcore
Not sure what the pistons are, is it a 1.8 or a 2.0? What does the bore measure?
The head has been welded up to use a Zetec headgasket. Much better.
The exhaust ports are very big. They look like 39mm. Mine have been worked and are 37mm
Wye Valley Hardcore
Valve sizes? Standard valves should be 42mm inlet 37mm exhaust. I think most heads can only accept a 43mm inlet 'oversize' valve without a crosshatch head but keep the same sized exhaust valves.
ekjim
17-08-2015 08:57 PM
