more fuel
25-04-2011, 07:36 PM
more fuel
at the moment i have bieges and a 044 fuel pump wat can i do to get more fuel to the engine wat flows more fuel then biege injectors ?
25-04-2011, 07:54 PM
25-04-2011, 09:00 PM
cheers do you know wat they flow ?
26-04-2011, 11:34 AM
Cossie yellows and greens?
Do they go straight in the EFi fuel rail?
26-04-2011, 07:35 PM
good point i assume so look the same
26-04-2011, 08:21 PM
i've got greys which fit the fiesta rail with no problems
27-04-2011, 11:35 AM
Martin & Luke - what management you running?
27-04-2011, 12:01 PM
27-04-2011, 05:49 PM
27-04-2011, 06:38 PM
megasquirt, tried ofab but its sh*t so i sold it then fitted megasquirt.
27-04-2011, 07:38 PM
Im tempted to go for MS too...
I dunno if they are "Greens" or not, i know they are green tho so maybe?
27-04-2011, 07:56 PM
27-04-2011, 07:58 PM
the problem is the cost to change the map on OFAB if want to change the imjectors or turbo etc.
27-04-2011, 08:01 PM
Yeah custom mapping is expensive once you get past the "stage1 and stage2" chips...
Il get mine to stage2 and then speak to MSD about a stage3 chip/map and go from there!
27-04-2011, 08:05 PM
the cost of a custom chip will pay for a megasquirt setup
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Brickhouse
14
03-10-2015 07:28 PM
20/20 vision
29-09-2015 11:27 AM
