S1 ARB on a S2, anyone done it?
Old 04-05-2011 | 06:50 PM
mattseries2's Avatar
mattseries2
Default S1 ARB on a S2, anyone done it?
Basicly want to fit the S1 Anti Roll Bar onto my S2. Whats needed to fit it? Gearbox mount not a problem as ive a Focus RS box fitted and it mounts from above.
What TCA's do i use? S1 or S2? or are they the same? (going for the adjustable ones (Compbrake)).
The bolts on the front cross member, how many line up? Do i need to put anymore in?
If anyones got any pics of one fitted that would be alot of help
Matt
Old 04-05-2011 | 07:02 PM
stuart collins's Avatar
stuart collins
just drill or change the front cross member and bolt it up, use a 16i roll bar if u can find 1
Old 04-05-2011 | 09:34 PM
mattseries2
Just had the cross member changed but not for an s1, should had thought snout it before really. I got a s1 arb for cheep off a mate so will be sticking with that. Stu, what arb you using?
Old 05-05-2011 | 07:03 AM
stuart collins
dont run a front anti roll bar on mine
Old 05-05-2011 | 07:43 PM
muz's Avatar
muz
Wye Valley Hardcore
Yes,Matt, I run one on mine. You need to drill 3 new holes. Two in the front crossmember and one in the drivers side chassis. You will need to insert some metal tube in the crossmember to stop it crushing when the bolts are tightened. Best way to do this is drill the bottom hole to the right size then drill the top hole slightly bigger so the tube goes in then bolt it all together.
Old 05-05-2011 | 07:47 PM
gus's Avatar
gus
any body roll?
Old 05-05-2011 | 08:39 PM
mattseries2
Nice one Muz, you running a S1 one or 1600i? Got any pics?
Old 05-05-2011 | 08:57 PM
muz's Avatar
muz
Wye Valley Hardcore
RS1600i job with MEF series 2 TCA's. Pics are in me thread mate. On my phone so can't post them here.
Old 05-05-2011 | 09:27 PM
mattseries2
What's the difference between the 1600i and the s2?
Old 05-05-2011 | 09:33 PM
Rob_DOHC's Avatar
Rob_DOHC
Have you driven it in anger yet mate? Was it worth it...
Rob,
Old 06-05-2011 | 09:09 AM
muz's Avatar
muz
Wye Valley Hardcore
RS1600i - Full, 1 piece aluminium front crossmember, thicker tie bars with slightly different ends, thicker ARB and toweye connected to the ARB clamp.
Series 1 - Cast iron 3 piece front crossmember, separate tow eye which connects to the ARB itself, thinner ARB and ties bars. All mounting points are the same as the RSi one though. Considerably heavier than the RSi.
Series 2 ARB
I'll let the pic do the talking
Rob,
Yes, it did make alot of difference to the way the car felt on the road, handled and torque steered. The standard car felt unsafe even before hand. However, I also fully polybushed the car, just a better freshly rebuilt and re-jelled diff, good coilovers and MEF TCA's all set up to Fords own Tarmac Rally car specs so it's hard to tell just how much difference the ARB alone made.
Old 06-05-2011 | 02:38 PM
mattseries2
I see the difference now, ill try look out for a 1600i then but cant be many around!
Old 06-05-2011 | 09:36 PM
luke19790_3's Avatar
luke19790_3
i have a spare S1 arb
155lee
27-10-2015 04:55 AM
Fezman1
02-10-2015 01:22 PM
IainRS1700T
25-09-2015 06:44 AM
truffleshuffle
10-09-2015 09:35 PM
saph in dorset
14-08-2015 10:10 AM
Quick Reply: S1 ARB on a S2, anyone done it?
