Edis or internal driver?
A friend is using a edis to run his ms1. Is there any advantage or adding an internal spark driver over the EDIS? The wiring will be simpler but is that it?
Ahh okay, but im sure the edis module will set dwell pretty perfectly with a ford coil pack!
Yes all is good, mine will be left alone, but i do still see a little noise which i believe comes from the ignition drivers, i would prefer it if there was no noise.
Rob,
Rob,
mk3ste
17-10-2021 10:09 AM
155lee
24-10-2015 11:11 AM
