what should co be on a s2
ofab,i done it my self,its got a fuel boost thing that im not sure how it works,
what makes you say its been to jamsport?
last time my car was touched by a tuner it was jano,but it was mfi at the time
Ask me a question!
When it was on MFi it wouldnt of left my workshop running more than 3.5% depending on what mods it had and power it was capable of.
Matt, in general most people who do the EFi conversion on their own ends up with issues similar to what you have with co readings off the scale and the system not working as it should.
This is mainly down to people not using the correct loom and not wiring it in to the car properly, using secondhand parts that dont work and cant be checked easy etc..
I would advise having it checked out before you damage anything.
Mine has always been running at around 3.2% althugh im buggered if ever need it adjusting as the little screw on metering unit is seized solid any tips on how to free it off greatly appreciated? tried soaking in wd40 etc but no joy, more I try undo it more the flat head screw rounds off
yeh it was on 3.5 at yours jano cos you showed me,the only second hand parts i got on it was loom and ecu,other then that its all new,just gota get the co right then its sorted,witch im hopin to do 2day
Yes I thought it should be an allen screw aswell actually oh well not to worry as so far its never needed to be adjusted in last 2 years of ownership
